mx 2300 print error
  • DINGO
    • 661
    mx 2300 print error
    Hi
    i have a mx 2300, that every times that y choose the print option "4bit", e get a print error?
    i m glad any help.
    thanks
  • bilyahn
    • Dec 2006
    • 1470
    Re: mx 2300 print error
    What driver are you using? Had this happen when they upgraded to Windows 7 machines and were using the wrong driver!
    Good luck.
    Bil
      • 22990
      I've had a similar experience as Bil. One of my customers with a MX-3501 upgraded the driver (just 'cause there was a new one), then they couldn't print. It turned out that a firmware upgrade was required to accommodate the new driver. It was the first and only time it ever came up. =^..^=
      • DINGO
        • 661
        ok, realy the costumer use w7, with pcl5.
        thanks, i wil check.
        my best regards friends
        • DINGO
          • 661
          good night friends
          i post here the solution, maybe can be usefull for someone to.
          the issue was in the port configuration, it was in raw, and i change for lpr, and now
          works fine.
            • 22990
            Congratulations! =^..^=
            • DINGO
              • 661
              I am sorry for my poor english to be able to help more on what i know
              regards
                • 22990
                There is no need to apologize. Yours is not the best or the worst. =^..^=
