LSU or Something Else - ARM350N
  • MFPs R Now PCs
    MFP Tech & I.T. Manager
    • Jul 2011
    • 156
    [CQ] LSU or Something Else - ARM350N
    We have a Sharp AR-M350N that when making a copy or a print will:
    1) shifts the copied original image to the left edge so far, the left side of the image is cut-off
    2) "ghosts" the copied original image as an exact duplicate to the upper right of the original image but its very light and made of a lot of little dots
    3) the "ghost" image will be turned at a 45 degree angle (sometimes)
    4) there are black smudges (lots of little dots)
    5) the copy/print is enlarged
    Now, I believe its the LSU and the dead give away are the dots (black smudges and the ghosting) but others say its impossible for a failing polygon motor to cause enlargements
    Your thoughts anyone? (Doesn't a slower spinning polygon mirror "stretch the image"?)
    It does not matter how slowly you go as long as you do not stop. –Confucius
  • igi
    • 1507
    Re: LSU or Something Else - ARM350N
    hi
    is self print from the copier does same problem?
    if does laser/poligone unit most likely faulty.
    cheers
    PS-faulty poligone motor can cause funny outputs.
    • lky1978
      • Mar 2009
      • 483
      Can put some sample to us?
        • 23009
        If it's second sides that have this most interesting quality problem you probably have a bad DF harness. See below:
        Digital image breakup on 2nd side only of 2 to 2 duplex. Missing elements from first copy appear on next consecutive 2nd side (even with a different original). Broken up image is reduced by from 55% to 95% in feed direction only, crossfeed is always 100%. Defective DSPF harnass. Replace the DSPF harnass (DHAI-3166FC11).
        Does that sound similar? =^..^=
        • mad
          • Jul 2010
          • 25
          hi... i have the same problem but on different model... do you remember the solution?... thanks in avance!
