MX-M350 Background
  • RSCA
    • Jul 2008
    • 112
    MX-M350 Background
    If I change and calibrate developer copy looks fine for about 2 or 3 days. I swapped developing units. Cleaned toner sensor. New drum. Please help.
  • bilyahn
    • Dec 2006
    • 1470
    Re: MX-M350 Background
    What's the developer calibration number when it stops and when you replace it? What ROM version, newest is 3.03.J0. Can you scan an image for us? Are you dumping developer?
    Good luck.
    Bil
    • RSCA
      • Jul 2008
      • 112
      The calibration number on Monday was 88. The one before that was 98. No developer dumping. Basically the copy looks fine except the background. It is also not consistent. Sometimes you can hardly tell there is background and other times it's really obvious. The copy doesn't look over-toned and there is no excess toner misting into the machine. If I scanned a page I'm not sure it would even show up. I just downloaded the current firmware. Not sure whether theirs is current or not but will check.
      • bdcrandall13
        • Sep 2010
        • 236
        Have you checked the exposure? Either in the system settings under copy/initial status or under sim 46.
        • RSCA
          • Jul 2008
          • 112
          Haven't done anything with exposure. Since it's not consistent I wouldn't have thought to go there.
          • rainmaker
            • Jul 2011
            • 77
            did you check to see if the copier is level? I have seen this to be a issue also.
            • Akitu
              Legendary Frost Spec Tech
              • Oct 2010
              • 2595
              What's your copy count? You said you've changed the developer and drum, was it at a PM interval? Have you changed your transfer roller? If you don't change the transfer roller that will definitely give you some background issues...
                • 23009
                Is it second side only? Maybe DF position, hinge wear, or white plate mis-alignment? =^..^=
