Port 21
  • Peter Sim
    • Sep 2008
    • 445
    Port 21
    Hi all, need info and help.
    Because anti virus block port 21 for ftp, causing the scanner cannot use ,can we change to port like port 25 or other?
    Thank you ina dvance.
  • linuxxpwin
    • May 2008
    • 205
    Re: Port 21
    ports are assigned to certain things with a piece of hardware: port 21 is assigned to FTP
    port 25 is assigned to SMTP (Mail)
    pop3 on 110 (mail)
    and so on, what you can try is to give specific information on your firewall to allow connections from an assigned IP Addess or addresses. or maybe depending on the firewall pgm you are using you can give permission to the program wanting to use the port.
    List of TCP and UDP port numbers - Wikipedia, the free encyclopedia
    if you reassign a port make sure it does not conflict with something else, or stop another service from running
    Linuxxpwin
    Linuxxpwin
    • TheOwl
      • Nov 2008
      • 1732
      Re: Port 21
      Create an exception in the antivirus firewall.
      Antivirus patterns as such won't block ports, but the firewalls the are installed along side some AV software will.
      What AV are you using?
      Does the machine scan when the AV is disabled?
      Linuxxpwin is spot on the money in that certain ports are assigned to certain protocols. Port 25 that you thought about changing the FTP service to is assigned to SMTP (Outbound email or Simple Mail Transfer Protocol) and would cause issues with that PC sending email.
      Fix the problem, don't create messy work arounds.
      • Peter Sim
        • Sep 2008
        • 445
        Re: Port 21
        Thank you and sorry for the late reply.
        Need to make some correction on this issue.Is not AV problem,is the port problem.
        The IT guy from the factory say that the two port 20 and 21 got the virus issue.So yesterday they totaly close down the two port causing the scanner cannot scan.And they push back the issue to us and wanted us to reassign another port for them.
        I need help and your expertise to guide me.
        1)Can we change the port ?
        2)Ask them to assign another port number?
        3)Where we can change the port?From sharpdesk destination control?
        Thank you .
        • ZOOTECH
          Senior member of CRS
          • 3374
          Re: Port 21
          Thank you .
          Use port #4687 - change it in the Network Scanner Tool tab for System Options.
          • TheOwl
            • Nov 2008
            • 1732
            Re: Port 21
            Just let the IT guys know that by shutting down port 21 and opening another port is NOT going to solve the problem of viruses. It's kind of like drilling a hole in a bucket, saying there is water come out of that now, patching the hole up and then drilling another one right next to it.
            If they are that worries about port 21, create an exception that says traffic on port 21 can only come from this IP address and use the IP address of the copier.
            I myself am an IT person and I use FTP on its assigned port of 21 all the time. If I were to get a virus through on that port, then I would look at tightening the security around that port.
            • Peter Sim
              • Sep 2008
              • 445
              Re: Port 21
              Thank you again for your reply,i will try to talk to the IT guy,because we have 20 unit of ar-m350/450 on the plant,and hope that he will listen to our advice.
              Other than this, can we use scan to email option on this machine?
              • Peter Sim
                • Sep 2008
                • 445
                Re: Port 21
                I need to change the port to higher than #4687?
                • ZOOTECH
                  • 3374
                  Re: Port 21
                  Just follow Owls recommendation above.
                  • linuxxpwin
                    • May 2008
                    • 205
                    Re: Port 21
                    As an IT Professional I have to agree with my colleagues above about the port settings, using a different port will not solve the problem as the initial problem is still there and would now allow any other ports to get infected, best practice would be to direct particular addresses to be received by the ports only.
                    example port 25 being smtp port can be set to only receive emails from a certain IP Address or addresses only say anti spam software.
                    as with my other colleagues I would say assign only specific traffic from certain addresses only.
                    Linuxxpwin
                    • Hansoon
                      • Sep 2007
                      • 3347
                      Re: Port 21
                      Sorry for the stupid asking from a copier tech trying to understand IT: Where to find those settings?
                      Hans
                      “ Sent from my Intel 80286 using MS-DOS 2.0
                      https://www.copytechnet.com/images/smilies/biggrin.png
                      • TheOwl
                        • Nov 2008
                        • 1732
                        Re: Port 21
                        Hansoon,
                        It completely depends on the software as how you would go about making an exception. Normally if I don't know the the software, a quick Google search normally fixes my issue. Say you are you using SEP (Symantec Endpoint Protection), I would search for:
                        Firewall exception Symantec Endpoint Protection vX
                        For SMTP, there are also other things that can contribute to to filtering out traffic on port 25 such as the email server like Exchange 2007 and 2010 does straight out of the box. With those versions of Exchange, everything has to be authenticated and secured with TLS unless you say other wise. It won't even accept email from outside domains coming in until you tell it as well.
                        • Hansoon
                          • Sep 2007
                          • 3347
                          Re: Port 21
                          Thanks Owl.
                          Hans
                          • linuxxpwin
                            • May 2008
                            • 205
                            Re: Port 21
                            ok, does your network carries a firewall router, in which your entire network connect through? including your network copier/printers. rule exception and tightening is done mostly at those locations, if you are using print servers to control your machines.if so then direct your firewall to the server server to printer/s or ask your network administrator for assistance in configuration.
                            it is pretty easy once you have the info needed.
                            you can tell your firewall only to receive connections on port 21 or maybe you need a better virus pgm, in my case I have a print server build from Linux where all printing from the windows network passes through on assigned ports only and to receive from internal TCPIP ports and not from every where.
                            All traffic flows from network to windows server then to Linux print server with Spam filter then once verified is send to printer.
                            This sounds like a lot of work. But remember this is my setup.
                            Look at yours and see what you can change..
                            Linuxxpwin
                            • Ceechtay
                              • Sep 2011
                              • 157
                              Re: Port 21
                              Thank you .
                              It may help to know what model copier that you are using and what method are you using to transmit scans.
                              From your initial post, it would appear that you are doing "scan to FTP" destinations, but in this quoted message, it appears you may be using SharpDesk (which is basically FTP also). If you are using SharpDesk, the default is port 4687, which can be changed on the System Options tab when you open up the Network Scanner Tool. You can also verify that any updated profiles have the new port by looking at the destinations in the Address Book on the copier's webpage.
                              If you are using FTP destinations (instead of Desktop destinations, which are for Sharpdesk), you cannot specify the port (as far as I know). It uses port 21 by default. If this is the case, then you would need their IT staff to open up those ports in the firewall for only the IP addresses of the copiers.
                              If you are using Sharpdesk, the problem could be that even though you are using the default port (4687), their IT staff stopped all FTP traffic on all ports. If that is the case, you could have them open up FTP traffic for port 4687 to enable Sharpdesk to work.
                              Good luck!
