1 1/2 inch black to fade band when using adf
  • pontiac
    • 420
    COPIER IS A SHARP ARM 277 PROBLEM ONLY HAPPENS WHEN USING DOC FEEDER,BAND IS OPTICS CHECKED AND CLEANED NOTHING BLOCKING LIGHT PATH.WHITE REFERENCE PLATE ON ADF IS CLEAN NOTHING BLOCKING PATH. I CHECKED THE LAMP AND TO MY EYE'S IT LOOKED LIKE EVEN LIGHT FRONT TO BACK . COPIES IN REDUCTION AND ENLARGEMENT ALSO HAVE BLK BAND. THE BAND IS ALONG THE BOTTOM OF PAGE. CUSTOMER IS PLACING THERE DOCS IN LETTER R SO THE BAND DOSE NOT SHOW UP. i FEEL IT'S THE LAMP BUT DON'T WANT TO ORDER WHAT I DON'T NEED. THANKS FOR REPLYS
  • rainmaker
    • Jul 2011
    • 77
    Re: 1 1/2 inch black to fade band when using adf
    what model are you working?
    • pontiac
      • 420
      Thanks rainmaker i edited and added sharp arm 277 to my post.
      • rainmaker
        • Jul 2011
        • 77
        i would check to see if the width guides are correct.what i mean by this is on a blank sheet of paper make points on the paper all a round ^ and run it off the glass and then run it thru the df.if the ^ dont look the same.i would adjust the df width guide useing test command 53-6.you might have to replace the adjable resister that adj the width guides.good luck.
        • igi
          • 1507
          Hi
          firstly check paralelism of you scaner
          then adjust the red screws of the rail in the optical unit
          good luck
            • 22930
            I've seen something similar on a Tiger or Jupiter. In my case the SPF white plate was mis-aligned with the slit glass. The tech had done it to compensate for a SPF skew by adjusting the right SPF hinge, but instead had screwed up the image quality.
            On the AR-EF1 and AR-EF3 I took my ruler and measured the edge of the white mylar guide to the edge of the slit glass at the front and at the back of the machine. Obviously it's fairly easy to read the ruler at the front, but it's kind of tricky to read the ruler at the rear with the SPF mostly closed.
            Another way to get is fairly close is to just line up the corners of the SPF with the top cover of the machine. It's less accurate, but should get you to a usable position. =^..^=
