2-2 copying, paper stops in the middle of the right drawer transport during the second pass. Replaced sensors and rotten plastic transports above fuser. Nothing helps, Any Ideas?
AR-M208 Duplex Jams
I have seen this:
Misfeeds first side duplex (jam code PIN_DUP) at the registration roller (duplex only). Worn duplex mylars on the right door (35k duplex copies). Install (4) new style duplex mylars (PSHEZ0307QSZ1).
=^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^= -
Thanks for lending your time and experience
I will order/replace and let you know friend. Thanks againComment
geordie40
Duplex jams
Hi I had a similar problem on a sharp arm 207 (i think its the same model just uk version) Ichanged duplex motor, drive gears, belts etc all to no avail, in the end got a Sharp UK tech to come and look at it. Sharp issued a tech bulliten on this problem, it was down to a change in manufacture. Here is the link to the page
