AR-M355 Not adding toner
  • THINKINK01
    • Mar 2009
    • 31
    [CQ] AR-M355 Not adding toner
    Suddenly this machine just started making very light copies. Changed developer, new toner, and performed initialization, 25-2. Two days later it's back to light CQ. Toner motor turns. Toner sensor displays correctly. Forced toner replenishment (10) overtones after being run 3 times but then it's OK for another couple of days.
    Overall CQ is good and sharp in both print and copy modes, but light as in poor development. Currently client is using high grade compatible toner, but developer I replaced was OEM.
    Could transfer roller/drum be causing this problem? (Previous service history on this unit is unknown).
    Thank you for any input.
  • Akitu
    Legendary Frost Spec Tech
    • Oct 2010
    • 2595
    Re: AR-M355 Not adding toner
    What's the current volume on this machine?
    • THINKINK01
      • Mar 2009
      • 31
      Meter count is 256,344. Client making appoximately 200 copies/faxes/prints per day. Retail location open 7 days.
      • Akitu
        • Oct 2010
        • 2595
        Your fuser is overdue for maintenance by 56k, something to keep an eye on. Transfer roller should have been changed as well.
        You may want to look at sim 46-2 and adjust the density if you're still having light print outs.
        *Edit* Try a 44-6 as well for procon, should also help your fading. Try before the 46-2.
        • oldrn
          • 166
          When was this toner installed? How confident are you in the quality of the toner? Blacks are black after you return and do Sim 10 or do you end up with an overtoned light copy/print?
          • THINKINK01
            • Mar 2009
            • 31
            The toner was installed on Thursday 06/14 at the same time the developer was replaced.
            According to Q2 Products, who supplies the toner, the formulation is the same polymer grade as used in the OEM. Of course as we all know not a single OEM manufactures their own toners anymore so my confidence is as high as the reputation of the company that sells it!
            After Sim 10 is run blacks are black with some background, but nothing close to what the machine was producing right after the developer was replaced. Visually it appears that the trailing edge of all solid fill letters and images are a bit less filled-out. After 10 copies/prints the background clears and the print is acceptable, but not great.
            • DavePo
              • Jul 2008
              • 305
              If possible I would suggest that you replace the toner with a OEM toner also you would have to replenish the developer as well as it would be compromised. Along with the other suggestions for 44-06 etc.
              • THINKINK01
                • Mar 2009
                • 31
                I finally had the change to try some of the above suggestions today. None made any perceivable change in CQ.
                It was interesting to learn that this machine doesn't have a SM 44-6. SM 44 only has 1, 4, 9, 15 submode choices. Selecting 6 does nothing.
                Something else seemed to change as I was running 25-2 to confirm all was working internally, the program terminated with a display of TROUBLE!! Code EE-EL at the top of the LCD. Just exiting SM doesn't clear the code, but re-starting the machine does.
                I toned the machine with SM 10 and made some adjustments with SM 44-4 and the solid fill is a lot better, and the CQ is darker. I'll have to check next week to see if it stays like this.
                  • 23010
                  The only time you should run 25-2 is immediately after a developer change. For the purposes of checking developer density you should run 25-1 which does not store a new density value at it's conclusion.
                  The two things I would look at are worn transfer roller gear, and change to OEM toner. The worn transfer roller gear will cause developer to dump in the vertical path. And the aftermarket toner ... well there is no such thing as "high-quality" aftermarket toner.
                  Start with a fresh bag of developer. Clean out the developing unit completely (not just the cursory shake). Confirm that the empty developing unit turns smoothly. Add new developer. Run 25-2. (What value do you get? anywhere from 95 to 105 is typical.) Reset developer count. Check or replace transfer roller gear. Vacuum out the High-quality aftermarket crap. Install OEM toner.
                  • kingpd@businessprints.net
                    • 921
                    Hey DavePo,
                    Do you work for Philips in Williamsport by chance?
                    • DavePo
                      • Jul 2008
                      • 305
                      Originally posted by kingpd@businessprints.net
                      Hey DavePo,
                      Yes I do.
                        • 921
                        You guys have been around a very long time. Still a family owned dealership I think.
                        Yes I do.
                        • DavePo
                          • Jul 2008
                          • 305
                          Yes it has its over 125 years and 4th generation.
                            • 921
                            You don't see that too often anymore.
