AR 207 print question
  • mlbcopiers
    • Oct 2007
    • 34
    I have a customer with a Sharp AR 207. They want to set the copier up to use the network print.
    I have an old print board from some Sharp copier. I am not sure what model number of the copier. The board is an "andromeda GDI PWB Ver 1.0".
    Can I use this board in the copier to run the printer?
    If I can, then I can use the Pricom 3100 to connect to the network.
    Is this possible?
    Can I get the print driver for this off Sharp's web site. (I have the disk for the Sharp "AR M207", is this compatible?)
    Thank you for your imput.
    P 1</B>
    • 23009
    Sorry, mlb.
    Andromedas are AR-M237N, AR-M277N. I believe that this is the standard parallel port which must be removed to install the TCP/IP network card. It won't work on a Panther.
    The driver is wrong too. The driver for a Pegasus (AR-M207) won't work on a Panther (AR-207). The mechanical parts are all the same, the electrical parts are all different.
    For Parallel printing you need:
    AR-PB8 Network Expansion Kit
    AR-PA1 LCD Panel Kit
    For Network printing you need:
    AR-PS1 PS2 Expansion Kit
    AR-NC3D Network Interface Card.
    Good Luck finding all these boards. And if you do find them it will be cost prohibitive to follow through with.
