Sharp AR-M355U Trying to setup USB printing on Win 7 64 bit
  • colgrimes
    • May 2012
    • 64
    #16
    Re: Sharp AR-M355U Trying to setup USB printing on Win 7 64 bit
    The GDI drivers are used for USB printing.
    Sometimes it will extract the package but when it's plugged in it doesnt recognize the printer. In this case, once the driver package setup has been run, it places the extracted .inf file in a folder on the C drive under drivers.
    Once it's in here you can do a printer wizard and use the USB port and "have disk" to the drivers folder on the C drive for the .inf file.
    Hope this helps.
    colgrimes
    The Printer Guy
    CopierCollin.com
    Hybrid Honest Sales/IT
    • farooq
      #17
      Sharp usually releases SPLC drivers for USB GDi printing. PCL drivers will not work. these drivers are available along with pcl drivers for downloading. i guess using SPLC (or SPCL) should solve the problem. Farooq
      • Doug Money
        • Nov 2011
        • 41
        #18
        Originally posted by lky1978
        the ar-p20 come with two dimm cards and one network card.One is BOOT dimm and another is MAIN dimm.
        You need to replace both dimm cards then you can key in the product key. The product key need to be requested with sharp by using the application no. that come with the ar-p20 kit.
        the ar-p20 already discontinued long time ago.
        Is it possible to use an AR-P20 from another machine and get the product key still?
        • ZOOTECH
          Senior member of CRS
          • 3378
          #19
          Nope, not without an act of God (product key support).
          • Doug Money
            • Nov 2011
            • 41
            #20
            Zootech, do you mean Sharp won't give another key?
            • lky1978
              • Mar 2009
              • 483
              #21
              The productkey was derived from sharp document solution division in japan by using the machine serial number. So you cant use same product key with different serial no.
              • Doug Money
                • Nov 2011
                • 41
                #22
                No, what I am trying to find out is, If I take print controller from machine A and install on machine B, can I get a new product key for the new combination of Machine B and controller from Machine A? Thanks.
                • lky1978
                  • Mar 2009
                  • 483
                  #23
                  I think cant. But you can try it.
                  • draph
                    • 132
                    #24
                    Did you try to print to it using simple generic drivers?
                    • Doug Money
                      • Nov 2011
                      • 41
                      #25
                      draph, it appears that Sharp disabled the local printing function so people could not use thrid party controllers and have to pay ransom to Sharp.
                      • draph
                        • 132
                        #26
                        That's right! Put memory in gear now. AR-P21 NIC card, hard drive etcetera. The "U" was never intended to print straight from the box.
                        So why did it come with two ports? Have to ask the great minds of Sharp I guess.
                        • dibyendu
                          • Jan 2011
                          • 53
                          #27
                          printer
                          I think printer spooler service is disabled by the system administrator in that computer. Go to my computer right click than go to services here you see printer spooler service, make it enable. Now go to printer console u can see ur printer.
