mx2310u
  • dibyendu
    • Jan 2011
    • 53
    [Dead] mx2310u
    Hello friends.
    I have a problem in one new mx2310u machine. After installation 3 month it working fine. Now the problem is when power is given to the machine no display is glowing. Control panels small led is flowing and fan is rotating . Heater lamp and scanner not glowing. I have cleaned ram and Rom in mfp controller pwb but still machine is dead. I have already cross check scanner controller pwb, dc power supply and pcu pwb. Plz help me to out of the problem. Customer is very annoyed..
  • sharphead
    • Aug 2009
    • 271
    Re: mx2310u
    Always annoying when its a new machine.
    Try disconnecting finisher/ extra trays if there are any installed you could also tray the firmware upgrade from dead method
    • Akitu
      Legendary Frost Spec Tech
      • Oct 2010
      • 2596
      Re: mx2310u
      I've heard that reseating the SD card may resolve this error, I haven't tested it myself personally though.
      • JustManuals
        • Jan 2006
        • 9919
        Re: mx2310u
        Paul@justmanuals.com
        • leogets
          • Jul 2012
          • 5
          Re: mx2310u
          Confirm the status of the LED (red) below the CPU heat sink on the MFPC PCB
          If the LED is ON the SD card is probably faulty
          Once you replace the SD card you will need to force firmware upgrade
          lee
          • dibyendu
            • Jan 2011
            • 53
            Thanks friends, the said problem solved after replacing the MFP CONTROLLER PWB.. Thanks again for your replies.
            • Akitu
              • Oct 2010
              • 2596
              Re: mx2310u
              Thanks for the response, but for the sake of curiosity, was the SD card replaced/reseated prior to the MFP Control PWB?
