MX3110 special sims
  • gwaddle
    • May 2009
    • 782
    MX3110 special sims
    Does anyone know how to get into the special sims on this model of machine? Yes I am certified and yes I have a manual.
    I know I should be ashamed of myself. Strangely though, I am not.
  • Akitu
    Legendary Frost Spec Tech
    • Oct 2010
    • 2595
    Re: MX3110 special sims
    I'd have to assume it would be the same as previous models.
    • gwaddle
      • May 2009
      • 782
      No there is no CA key on the screen where you enter the code. On normal machines the code is # * CA #.
      • Akitu
        • Oct 2010
        • 2595
        I didn't look at the op panel, but you're correct. No CA key, how bizarre... Perhaps that code might best be edited out to prevent it getting into the wrong hands.
        • spanky
          • Sep 2012
          • 468
          Press the home key twice and the touch screen will show you the version of firmware that is installed on the machine.
          You then touch the touch screen where the version number is showing. You then enter the # * C * using the keys on the touch panel.
          • ZOOTECH
            Senior member of CRS
            • 3375
            Spanky, that's how to get into regular TC, not the special sims.
            • Akitu
              • Oct 2010
              • 2595
              I may have an answer for you later today, provided nobody beats me to it. Will respond with the command as soon as I have it, if I get it.
              • ZOOTECH
                • 3375
                Could it be the '//' which I couldn't find a definition? I tried several combinations with that without success; hope you have better luck.
                • Akitu
                  • Oct 2010
                  • 2595
                  • gwaddle
                    • May 2009
                    • 782
                    One of the guys here was talking to tech support this morning and asked them, they said the special sims aren't there anymore. I don't believe that but that's what he said. Thanks for the responses. Zootech, I couldn't find anything that said what the // is for either. Apparently that's a secret too. I really don't like these machines.
                    • mojorolla
                      The Wolf
                      • 2630
                      I can assure you from personal experience that it does exist. Also, you do not need any sort of special firmware. Those who work for Sharp have been told that if it leaks out, they will be terminated. If someone wants to discuss this further, please PM me.
                      • Sharp2
                        • Oct 2012
                        • 7
                        It seems that Special Sims on all the new machines is a big secret.
                        • Akitu
                          • Oct 2010
                          • 2595
                          They're secret for a very good reason... Last thing anyone needs is for some scumbag salesman to get a hold of the codes and start resetting meters to 0 and pawning off used machines as new. Then we're all sunk, which is why I imagine they've been so secretive about them now.
                          • igi
                            • 1507
                            hi
                            all
                            unfortunatly i am in the same boat like the rest of you guys,
                            on all the previous models was no problem to get the secret sims,
                            but on this range i tried to figure it out for a week,still no succes.
                            • harleyrider
                              • Oct 2011
                              • 348
                              I was @ sharp last week and they told me the "special sims" are no more.
