MX3110 special sims
  • igi
    • 1507
    #31
    Re: MX3110 special sims
    Originally posted by Akitu
    I don't see why anyone should be resetting copy counters, regardless of whether the machine went out on tenders or demo. It's just underhanded, it would be like resetting the odometer on a car lot after every test drive.
    Hi
    not for sake of reseting counters.
    problem with eeproms or pwb.
    it is much faster to fix the counters by yourself, then sending it to japan.
    • Akitu
      Legendary Frost Spec Tech
      • Oct 2010
      • 2595
      #32
      Originally posted by igi
      Hi
      Elevated sims are great for that, yes. Not for resetting copy counters. I use elevated sims only when absolutely necessary.
      • igi
        • 1507
        #33
        I may have an answer for you later today, provided nobody beats me to it. Will respond with the command as soon as I have it, if I get it.
        and its later in a day?
        • ZOOTECH
          Senior member of CRS
          • 3376
          #34
          No, it's later this decade.
          • igi
            • 1507
            #35
            ok lets try something easier,
            do you want to build a snow-man?
            • ZOOTECH
              • 3376
              #36
              Will it give us the entry to the special sims?
              • igi
                • 1507
                #37
                probably not,
                I just like the snow-man
