MX3110 special sims
  • Akitu
    Legendary Frost Spec Tech
    • Oct 2010
    • 2595
    #16
    Re: MX3110 special sims
    We have reason to believe otherwise, as posted, I was told there was special firmware involved, and others have heard other things. We'll figure it out one way or another...
    • mojorolla
      The Wolf
      • 2630
      #17
      There can only be 38,416 combinations with four keystrokes in the sequence.
      Let the fun begin!
      • Akitu
        • Oct 2010
        • 2595
        #18
        Does it lock you out after so many incorrect guesses? If not then someone could launch a brute force attack through VCN and have the code within minutes.
        • mojorolla
          The Wolf
          • 2630
          #19
          At the machines, you get 5 guesses before the machine locks. I am not sure about VNC though....
          • igi
            • 1507
            #20
            hi all
            what happens when it locks up
            is there a way to unlock?
            • Akitu
              • Oct 2010
              • 2595
              #21
              Originally posted by igi
              hi all
              Not having tried it, I would have to assume maybe a 10-30 minute lockout timer.
              • igi
                • 1507
                #22
                sweet
                • mojorolla
                  The Wolf
                  • 2630
                  #23
                  There is a "Release Machine Lock" button in the web page. I don't remember off the top of my head where, but I want to say in the security settings.
                  • Akitu
                    • Oct 2010
                    • 2595
                    #24
                    I believe that one is for user authentication purposes when a user locks themselves out trying to guess their own passwords...
                    • tmaged
                      Owner/Service Manager
                      • Oct 2008
                      • 1897
                      #25
                      That's only for files that had the incorrect password three times. They are then greyed out, until they are released. At that point the admin can delete them if the code is forgotten.
                      Hope that helps !
                      -Tony
                      www.dtios.com
                      Become a fan on Facebook
                      • mojorolla
                        The Wolf
                        • 2630
                        #26
                        I had some rare, free time today and attempted to VNC the combinations to the machine. The lag over the network made it clear this would not work; a crossover would probably be just as clunky.
                        • Akitu
                          • Oct 2010
                          • 2595
                          #27
                          Maybe it would be better to try on a 4111/5111? I hear they support gigabit lines...
                          • igi
                            • 1507
                            #28
                            I may have an answer for you later today, provided nobody beats me to it. Will respond with the command as soon as I have it, if I get it.
                            hi
                            any luck yet
                            • manjunathskm
                              #29
                              hi
                              all
                              unfortunatly i am in the same boat like the rest of you guys,
                              on all the previous models was no problem to get the secret sims,
                              but on this range i tried to figure it out for a week,still no succes.
                              It's True my friend. Sharp doesn't want Third Party players to Reset the Meter Reading and re-sell the used m/cs. But, again we, authorized dealers are unable
                              to reset the counters of Demo m/cs in the Show Rooms as well as the m/cs sent out for the Demo for a day or two especially for the Tenders. We are stuck.
                              • Akitu
                                • Oct 2010
                                • 2595
                                #30
                                I don't see why anyone should be resetting copy counters, regardless of whether the machine went out on tenders or demo. It's just underhanded, it would be like resetting the odometer on a car lot after every test drive.
