Sharp MX5500n powering off
  • David Scott
    • Sep 2025
    Weird problem I am having with this sharp mx 5500n. I returned to this machine with the idea of a simple fix of replacing a control panel.(Did not get that far) Now I have a dead machine and only when I unplug and plug back in the pwr supply powers up and after 10 seconds it shuts down. Repeatedly does this. I have check voltage in wall outlet and i am getting 120volts and same reading out of pwr supply until it shuts down. No lights on control panel light up the entire time.
    I have done a shotgun approach with a parts machine i had so basically switched out all boards in machine. I thought it might have been that i was troubleshooting with back off machine but i have found no door switches anywhere that would prevent machine powering up and also placed covers back on to re assure this. 22 years of service this one has me stumped! Small one man operation here and would love some advise! Thanks!!!
  • rainmaker
    • Jul 2011
    • 77
    Re: Sharp MX5500n powering off
    does the copier have a network cable plugged into the copier?if it does try to shut the copier off and unplugged the cable from the copier..i have seen this happen where it would shut off and on...good luck
    • David Scott
      No the network cable is not attached. thanks
        • 23010
        Have you tried swapping fusers? On older Canons, an open fuser lamp or exposure lamp shuts the main switch Off after ~5 seconds. =^..^=
        • David Scott
          Yea i tried fuser from my parts machine and tested continuity with meter on lamp (good) thanks
          • rainmaker
            • Jul 2011
            • 77
            what does it do if you leave the front door open and turn the copier on ? does it still turn off? did it just start doing it by itself,meaning it has been working fine with out anybody doing service on it?
            • JustManuals
              • Jan 2006
              • 9838
              Paul@justmanuals.com
              • Akitu
                Legendary Frost Spec Tech
                • Oct 2010
                • 2595
                You said you changed boards, but did you replace the ROM chips with the ones from the new boards or re-use the original ROM chips? I had a similar issue when my PRGM2 BOOT ROM chip got corroded in a monochrome machine.
                • mojorolla
                  The Wolf
                  • 2639
                  Does it have a Fiery on it?
