AR-SP6 trouble in black line
  • Aungmyowai
    • Oct 2012
    • 5
    copy in black line at rear side when using ADU . copy from OC is good. all mirror and glasses are cleaned.anyone can help me
  • Akitu
    Legendary Frost Spec Tech
    • Oct 2010
    • 2595
    Re: AR-SP6 trouble in black line
    Does it do it on internal prints as well? Could be a worn drum or charge grid.
      • 23009
      Perhaps you might clean the slit glass. =^..^=
      • ZOOTECH
        Senior member of CRS
        • 3375
        This is certainly the first place to look (slit glass); the optics have to be absolutely parallel because the scanner moves all the way to the right to read from the slit glass, and copy from the glass can look ok if slightly off parallel.
        I believe there was a firmware upgrade also for this problem, but I'm not positive.
        • Akitu
          • Oct 2010
          • 2595
          OP said glass was clean. Seems to be a tech as well.
          • bilyahn
            • Dec 2006
            • 1470
            If it is at the very edge of the paper try adjusting sim 50-16 (SPF offcenter adjustment).
            Good luck.
            Bil
              • 23009
              If I could count the number of times somebody told me the slit glass was clean, and it wasn't ... =^..^=
              • Akitu
                • Oct 2010
                • 2595
                I completely agree. Never trust an end user...
                • JustManuals
                  • Jan 2006
                  • 9838
                  Paul@justmanuals.com
