AR-M207 jamming half way out of delivery unit and right before registration sensor
  • Guest
    Hey,
    I got a AR-M207 jamming out of both trays. When it jams one piece of paper is half way out of the delivery unit and the second is sitting right before the registration sensor. The registration sensor checks out just fine in SIM 30. Cleaned all the transport rollers and feed rollers. Has anyone experienced this before with these machines? And if you did what was the fix?
    • 23009
    Re: AR-M207 jamming half way out of delivery unit and right before registration senso
    What jam codes?
    • Guest
      PIN_ON jam code
      • bilyahn
        • Dec 2006
        • 1470
        Originally posted by srdrown
        PIN_ON jam code
        Have had this jam code and there are several things you can try. The first one I would check it the PF clutches in the back of the unit. Clean them and apply new grease, maybe even adjust spring tension on them (I believe there are 4 total and a PITA to work on a couple of them). Depending on the age of the machines there are 2 tech bulletins. One has you replace the paper cassette feed rollers and the other has you modify the cassette tray (we just replaced it)
        Good luck.
        Bil
