Sharp AR-M205 DV problem
  • Doug Money
    • Nov 2011
    • 41
    I have a Sharp AR-M205 that was traded in. It pulls developer about 1-1/2 inches back from the front of the machine. It takes a while(weeks) and then makes a nice little puddle of dv in the imaging section. Gets into the transfer charger, the drum unit and down onto the bypass. I have cleaned and looked and I can not find the problem. Parts replaced; Drum and drum frame with new charger. Dev unit with new developer, swapped right door from two different machines. Cleaned every piece of optics I can. Desassembled the LSU and cleaned it. Any other ideas that I have missed? Thanks.
    • 22996
    Re: Sharp AR-M205 DV problem
    It's usually a warped developing unit top cover or a warped upper seal that skims developer off the developing roller. I know it sounds silly, but some of our techs would layer a new seal over the old making the problem worse. One seal only, please.
    Also make sure the machine is level, front to back. Place your level on the copyboard glass. =^..^=
