Mx-m5001N
  • Sharpietech
    • Jul 2025
    [Misc] Mx-m5001N
    Hello ,
    I have a sharp 5001n that leaves little dots on my copies , this happens even if i clean and restatic primary belt and cleaning blade . Its almost as if the first transfer cleaner unit is defective. I took the belt out and i turned it and sure enough the dots appeared on the transfer belt ,so i changed the whole unit and a few months later the problem came back. Does any body had this issue as yet ?
  • JustManuals
    • Jan 2006
    • 9838
    Re: Mx-m5001N
    Paul@justmanuals.com
    • Sharptech0892
      • Aug 2011
      • 79
      Re: Mx-m5001N
      Had same problem, ended up putting another mx-310y1 in it.
      • Nachoman4life
        • Oct 2007
        • 212
        Re: Mx-m5001N
        If they look like 2 teardrops, the inside of the belt and the unit are contaminated. (> <) like this only front to rear.
        Where the heck is my spring hook?
        • Sharpietech
          thanks bro I chanaged the unit .
          • Sharpietech
            I changed the unit and it worked , however I suspect that fur like roller in the cleaning unit .
