Hello ,
I have a sharp 5001n that leaves little dots on my copies , this happens even if i clean and restatic primary belt and cleaning blade . Its almost as if the first transfer cleaner unit is defective. I took the belt out and i turned it and sure enough the dots appeared on the transfer belt ,so i changed the whole unit and a few months later the problem came back. Does any body had this issue as yet ?
