Sharp AL-1540cs reset after new drum
  • hap
    Hi,
    Hope you can help. Just installed a new drum and need to reset.
    Can't recall if it is "clear" key, then auto exposure key, then "clear" followed by "quantity" [24] "print", [07] "print", then "clear","clear","clear"
    Not sure. Hope you can help.
    thanks
    Hap
    • 22997
    Clear, Exposure Select, Clear, Exposure Select, 24, Start, 07, Start, Reset x3 to exit.
    • hap
      Thank you blackcat.
        • 22997
        De nada.
        • Papo
          • Oct 2008
          • 36
          reset procedure with out code.
          Tou must spin the white half way gear in the green drum cover all the way to the opposite dirreccion so that when the customer Installs a refurb drum unit it can reset the drum counter automaticaly.
          Other wise you can close the right door with out closing the front door shut off machine and simultainusly hit the little white switch close to the front door while you turn on the copier this will also clear the counter if you dont have the code with you.
