Hey all, I'm running into an issue today that I'm hoping someone has seen before. I set up a new MXB201D with an NB-11 and an FX12. I've set up anbout 12 of these in the past week without any issues. Then last evening I set one up and it faxes out fine but when it tries to receive it errors out. It picks up, and after a couple seconds it hangs up and gives 3 beeps, and the sending machine shows NG020023. Ok, I tried another fax unit, nope, another NB11, nope. Ok, new machine and new parts, same issue. Tried a THIRD machine, with a new fax, and a new NB11, same beeps, same error. I tried different fax lines (in another part of the buiilding), tried image memory clear, and 66-3 fax memory check, which says ok on the modem and ok on the flash memory.
I've revieded the error codes and I'll have to look into those further, but I find it odd that all of a sudden, all of the machines are failing?
Any ideas? I'm fixing to call the hotline in about an hour when I have time.
Stacey
Stacey
