MX-B201D fax error new setups
  • Sfish460
    • Mar 2011
    • 30
    [Error Code] MX-B201D fax error new setups
    Hey all, I'm running into an issue today that I'm hoping someone has seen before. I set up a new MXB201D with an NB-11 and an FX12. I've set up anbout 12 of these in the past week without any issues. Then last evening I set one up and it faxes out fine but when it tries to receive it errors out. It picks up, and after a couple seconds it hangs up and gives 3 beeps, and the sending machine shows NG020023. Ok, I tried another fax unit, nope, another NB11, nope. Ok, new machine and new parts, same issue. Tried a THIRD machine, with a new fax, and a new NB11, same beeps, same error. I tried different fax lines (in another part of the buiilding), tried image memory clear, and 66-3 fax memory check, which says ok on the modem and ok on the flash memory.
    I've revieded the error codes and I'll have to look into those further, but I find it odd that all of a sudden, all of the machines are failing?
    Any ideas? I'm fixing to call the hotline in about an hour when I have time.
    Stacey
  • Akitu
    Legendary Frost Spec Tech
    • Oct 2010
    • 2595
    Re: MX-B201D fax error new setups
    Stacey
    Try turning off error correction mode (ECM) and see what your results are. I can't say I've had this specific problem, but I do deal with faxes in a lot of boonie communities that don't have the greatest phone lines. ECM is usually the culprit when there are fax problems. The lines are good enough to transmit, but bad enough to give it some difficulty when it tries to correct the problem causing them to have some bizarre issues akin to your post.
    • Sfish460
      • Mar 2011
      • 30
      Solved::
      Short answer, firmware, long answer, yes we always do firmware, however, the machine fax firmware coming in, is higher than what sharp has on IDNC (shipped with 2.03, we downgraded to 2.01) oddly Sharps firmware must have corrupted, but in such a way as to only affect incoming faxes. Might wanna watch out for that, I'm not sure how many machines sharp sent with bad 2.03 fax firmware.
      Thanks again
      • Akitu
        • Oct 2010
        • 2595
        Solved::
        Thanks again
        I did my one and only 201 not but a few weeks ago. My own shipped with 1.00 firmware and had to be updated.
        Thanks for posting the fix.
          • 22999
          Good catch, Sfish. Firmware incompatibilities can be hard to catch. =^..^=
          • 914fan
            • Jun 2014
            • 7
            I am trying to download the firmware on a mxb201d. The maint utility only shows the copier is off. I have tried it in win 7 and in xp mode. I cant get it to load the driver for the "ar-download" device.
            Ive done firmware through xp mode on the 314 317 200d machines through serial ports
            but this one is killing me.
            HELP!!!
            • 914fan
              • Jun 2014
              • 7
              so it looks like to upgrade the fax on this machine i only need the fax firmware on a usb and I go to 49_2.
              I changed the fax firmware I had from fdl (i think) to .spf and A-Jaguar.spf. Both times it says there is no script and it cant load firmware.
              Can someone please send me the fax firmware to load and confirm im going about it correctly.
              Thank you
              tukituki@yahoo.com
              Ive read on this board for a dozen or so years and only recently officially joined. Awesome resource here in this forum.
              • Akitu
                • Oct 2010
                • 2595
                All flash drive firmware upgrades need to be performed on a device formatted to FAT16 or FAT32 format. NTFS WILL NOT WORK!
                This particular firmware upgrade still requires the serial connection actually. You were on the right track, just follow the directions in the manual and it should work for you. If you don't have the manual, our friendly neighbourhood manual salesman can look after your needs for the low low price of only $12.77!
                • CorbinDallas
                  • Mar 2012
                  • 56
                  I have seen DSL lines that are able to fax out OK, but will not receive unless set to answer after 0 or 1 ring.
                  • Akitu
                    • Oct 2010
                    • 2595
                    Apparently the prices have gone up and I failed to notice, they're now $14.77
                    • faxman28
                      • 436
                      Thank you
                      tukituki@yahoo.com
                      The spf file is the only file on the usb drive and renamed to A-Jaguar.spf(no other files can be on the usb , my usb drive is 2gb and fat32). go into sim 49-2, press start, insert usb drive into copier, the screen will show no script file , then switch to begin spf update, wait about 2min 30sec(according to instructions that comes with the fw file. ) Wait for the screen to show download mode download complete , then turn of copier and remove usb memory.
                      The latest fw on sharp idnc as 3 folders when the zip is extracted, maint folder (software for upgrade main body and instructions) folder with main body fw(dwl file) and folder with network bd/fax bd fw (spf file ,for usb thumb drive) this folder also has the dwl file in it but the dwl file still must be used with the maint utility software.
                      • 914fan
                        • Jun 2014
                        • 7
                        Thank you. I'll try a new sick. This one may just be on its way out. I always format my sticks to fat for Sharp. 32 doesn't work on old machines, but fat works on newer machines.
