Total Count stuck?
  • nathansipe
    just another tech
    • Aug 2009
    • 122
    Total Count stuck?
    I have an MX-M350N in the field that has been working great. It was brought to my attention by our billing department that something was wrong with the counts. Here are the last 5 counts. Why it took so long, I don't know.
    Dec 2012 339,735
    Jan 2013 339,588
    Feb 2013 339,442
    March 2013 339,976
    April 2013 339,724
    The customer was running about 20K per month on it until December. I know the customer is running the machine like normal. Basically, since December the total count is stuck on 339,000 but the last 3 digits of the count are going from 000 to 999 then back to zero but the 339 never goes to 340,000. Anyone ever seen this?
    I'm going there tomorrow morning to print a 22-6 and see if the machine has kept a count somewhere in its memory. I'm going to do enough prints to get it to go from 339,999 to 339,000 so I can see with my own eyes. Then I'll probably call Sharp.
    Best rule for troubleshooting.
    K I S S Keep It Simple Stupid
    • 22995
    Re: Total Count stuck?
    My first guess would be that the enduser has not been turning in valid counter readings. Yes, I'd have to go see for myself. 22-6 is a great place to look for a valid total count if indeed it is staying within the 339,000-339,999 window.
    The MCU PWB is the most logical choice if indeed the proof is the way you've described it.
    In 25 years I've only seen counter problems less than 6 times. 4 of 6 we're mechanical counters that had been inexpertly backed up. I've seen one mechanical counter that just had enough the second full time around (1,999,999 copies, the meter displayed: 999,999). And the last one had some sort of grounding problem causing the mechanical counter to flip backwards occasionally. I've never seen a virtual counter miscount.
    • JustManuals
      • Jan 2006
      • 9838
      Paul@justmanuals.com
      • copyguy1
        • Jul 2011
        • 142
        My question would be how are these counts taken if its from the print out are they giving the total count or just the prints or copies. you could hold the copiy key and see what that value is, the counts are store in different sp[ots. You may want to flash the frimware.
        • bilyahn
          • Dec 2006
          • 1470
          Print out a 23-2 list also. Would be interesting to see if the jam codes have the same copy counts. If this is like most MXM350's you should have a fair sampling of jams with dates and copy counts. Be very interested in what you find.
          Good luck.
          Bil
          • nathansipe
            just another tech
            • Aug 2009
            • 122
            They were giving us the total count by pressing and holding the copy button and they have like this for a couple years on all their machines. I had them print a total count sheet and it also said 339K.
            I went this morning and made 600 copies to see if the machine would go from 339,999 to 340,000. And it did. I got it up to 340,150 then I rebooted the machine and it went back to 339,406. I ran another 50 and rebooted. It again came up with 339,406. So every night when they turn the machine off, the counts get reset to 339,406.
            I did not print a 22-3 because I didn't read your post until I got back, but I did print a 22-6 before and after the reboot.
            As it turns out, when the machine is rebooted it changes all counters back to whatever count they were at for the 339,406 count. The total count, maint counters, dev/drum rotations, tray counters all get reset to whatever they were when the machine was at 339,406.
            I even took a video for the other techs and my supervisors to believe it. We switched out the machine for now. My first step is firmware, then possibly main board, but I thought the counts were kept on the Eprom. So if the Eprom is not remembering the correct data after reboot then I have real issues.
            • Akitu
              Legendary Frost Spec Tech
              • Oct 2010
              • 2595
              Sounds like you've got your problem nailed. Back up the EEPROM data to the HDD with sim 56-1 before doing any replacements.
              • nathansipe
                just another tech
                • Aug 2009
                • 122
                What will backing it up to the HDD with 56-1 do? I thought EEPROMs had to be burned with an EEPROM writer? Sorry, but I haven't had many EEPROMs go bad. Please fill me in.
                • Akitu
                  • Oct 2010
                  • 2595
                  More of a failsafe than anything. I haven't had any EEPROMs go bad myself, but I've always been told to back up the data regardless.
                  • ZOOTECH
                    Senior member of CRS
                    • 3375
                    Yep, have to agree with the backup - and I recommend that after every service call, do a backup, it will keep numbers and settings up to date.
                    • lky1978
                      • Mar 2009
                      • 482
                      back up eeprom data to hdd, change the eeprom(24c32) and restore from hdd.
                      first time i heard this thing happen.
                      • bdcrandall13
                        • Sep 2010
                        • 236
                        We had this happen on an MXM350U. It was a nightmare. The machine had been converted to an "N" machine by adding a print controller and also had network scan installed. So it had the special "P" flash roms on the MFP board that came with the print controller kit, as well as the product key assigned for the NSX1 scanner kit. We were told to change the Flash roms, which our tech did, but he changed them with the stock "N" flash roms, and it didnt fix the problem and created more. Unfortunately he tossed out the "P" flash roms and we had to purchase another printer expansion kit to get those.
                        We ended up having to change the EEPROM which I'm sure all of you know clears about everything. It did fix the problem though. We had also switched about the PCU and MFP board, along with the flash roms, before this problem was corrected. It all came back to the EEPROM.
                        BTW, the "stuck" count went on for about 6 months before anyone noticed. It would count up from whatever number it was at until the machine went to sleep or was turned off then it would always revert back to that number. After changing the EEPROM, and everything else we did, the problem has not resurfaced.
                        Good luck.
