Sharp AR-160
  • Kurt
    • 56
    Sharp AR-160
    As soon as you push the print button in goes into add paper. Tray is full. By-pass feeding is OK. First time l've looked at one. Sensor and where? Thanks, Kurt
  • mtech
    • Mar 2007
    • 307
    If you are working on an AR-160, then the actuator for tray 1 is probably broken or out of place.(thanks to the operator!) The part number for the actuator is MLEVP0024QSZZ. The sensor it triggers is CPWBF1177FC65, but i've never seen the sensor go bad. to replace one or both, remove the toner cartridge, dv unit and drum(really easy, 1 blue screw). Then just remove the cassette and flip the whole machine up onto it's back and your there. If it has two cassettes then separate the lower cassette and do the same. Sharp also has a AR-M160 model. This is completely different, but can have a similar problem. If you have an M160, then you need QSW-B0017QSZZ, and this is located behind the rear cover below the main drive and is really easy to replace. The cassette hits this switch and it tells the tray to rise (these go bad all the time) If the M160 has more cassettes, order additional sensors for each cassette.
      • 22997
      mtech has covered it.
      If it's an AR-160 the flag is probably just knocked off or broken.
      If it's an AR-M160 the tray microswitches very commonly are a problem. They're made very cheaply (like lots of thinks-Sharp).
