ARM350 black copy or scan thru ADF. Prints OK and flatbed copy ok.
  • ultimateprintsolutions
    • Jul 2008
    • 34
    I have a customer with older ARM350/Imagistics IM3510 that randomly (maybe 1 good page out of 5) has black scans/copies when using the ADF feeder. Some are completely black others start off with image and then 2/3 of page are black with no image at all. Cannot reproduce using flatbed. Prints are fine. I assume it is in scanner section, but is it board/cables/lamp. I don't think it is lamp because cannot reproduce using flatbed, but I have been wrong before.
  • JustManuals
    • Jan 2006
    • 9838
    Re: ARM350 black copy or scan thru ADF. Prints OK and flatbed copy ok.
    This Parts & Service manual can now be purchased for $12.77 and downloaded immediately after payment from:
    Paul@justmanuals.com
      • 22927
      My guess is that the scanner is not getting to, or not staying aligned with the slit glass. Are you getting line blurrs in scans made from the glass? I'd look at traditional things like: clean and lubricated scanner rails, drive cables-belts-pulleys, obstacles to scanner motion.
      There is a known quality problem with the AR-EF1 document feeder only when scanning with the document feeder, but is doesn't sound like your problem:
      Digital image breakup on 2nd side only of 2 to 2 duplex. Missing elements from first copy appear on next consecutive 2nd side (even with a different original). Broken up image is reduced by from 55% to 95% in feed direction only, crossfeed is always 100%. Defective DSPF harnass. Replace the DSPF harnass (DHAI-3166FC11).
      • copyguy1
        • Jul 2011
        • 142
        You may want to adjust sim 53-8 had one giving issues and this fixed issue adjusting far enough made it act up more often. This has to do with stop posistion of scanner. Good luck
          • Jul 2008
          • 34
          thank for the suggestions. i will add some samples to my post in the morning when I get back to office.
            • Jul 2008
            • 34
            My customer called and said it is now copying black from the flatbed.
            • NRTech
              • Apr 2013
              • 45
              remove the cable connector from the scanner to the printer engine and check all the pins. you'll probably have one our two that are bent out of shape and not connecting. carefully straighten these and reconnect.
              • lky1978
                • Mar 2009
                • 475
                yes, blackcat said correct. just replace the harness.
                  • Jul 2008
                  • 34
                  here are samples of what it is doing.
                    • 22927
                    Is this the internal report print, or a copy or the report? It makes a difference. =^..^=
                      • Jul 2008
                      • 34
                      copy of the report.
                        • 22927
                        Here's your short list: lamp, inverter, lamp cable.
                        As a test you should be able to go into simulation, remove the glass, then illuminate the lamp.
                        Does it light, does it flicker, does it stay off? If it lights and stays lit, try moving the scanner cable to see if it will go out or flicker.
                          • Jul 2008
                          • 34
                          thanks blackcat. looks like it is sim 5-3. i am going out there tomorrow. I will update once I run the tests.
