ARM 160 F5-02
  • yormets
    • May 2009
    • 336
    ARM 160 F5-02
    I know it's an exposure lamp fault. Is it the lamp? Looks good to me. How would you ever get it out? Is there a thermal fuse to check?
  • brewster67
    • Jul 2011
    • 167
    Re: ARM 160 F5-02
    You can check the lamp with sim 5-3. If it doesn't come on check connections of the ribbon cable. The next thing would be the bulb or the inverter PWB, Easiest way to change those is to pull the copy lamp unit out of the optics unit. The disassembly is on page 11-2 of the manual.
      • 23009
      Re: ARM 160 F5-02
      I came across something similar on an AR-162S. The cause was a severely overloaded AC circuit which blew the MCU. It's rare, but worth mentioning:
      "F5-02", "E7-05", occasionally clears, and copying can be resumed with no other symptoms on AR-162S. Copy Lamp, and CCD Black Level Reference errors, respectively. MCU PWB is damaged by dirty AC power (large inductive load very close). Replace the MCU PWB (CPWBX0096QSG2).
      Note: MCU part number will be different on AR-M160. Also I'd start with the more obvious causes like brewster suggests. =^..^=
      • JustManuals
        • Jan 2006
        • 9838
        Re: ARM 160 F5-02
        Paul@justmanuals.com
        • yormets
          • May 2009
          • 336
          Re: ARM 160 F5-02
          I replaced the whole scanner lamp assy. Still doesn't work. The main board goes bad on these?
            • 23009
            Re: ARM 160 F5-02
            I cannot add anything new to the original post. Use your best judgement. =^..^=
