It's got a fairly strange combination of symptoms: The customer complained of "lines". I'd try to scan a sample, but the anomaly is fairly subtle, and seen mainly in the fine line work, grids or text.
They're really compressions crossfeed. Not on the first page but all pages after.
- There is one compression per page
- They are always 58mm or 73mm from the leading edge with single example of 24mm.
- It only affects B&W images, not color. And not the black in a color image.
- It only affects LTR paper, from any tray. No compressions on LTR-R, legal, or ledger.
- The developed primary transfer image on the belt is pristine (no compressions).
- The compression can be seen on unfused (emergency stopped) pages that have not yet reached the fuser.
So I've narrowed it down to happening after primary transfer but before fusing. That leaves us with registration and secondary transfer.
Other things that I have noticed but may mean nothing:
- There is a texture pattern from the inside of the transfer belt that repeats at 9.13mm intervals. Almost like the belt was running over a contaminated metal roller, but 9.13mm circumference leads us to a roller diameter of 2.9mm. Could there really be a 2.9mm roller in the primary transfer assembly? And could it make any difference?
Does any of this sound familiar? =^..^=
