Yes it's an old machine, forgive me.
Copies off glass are as dead on perfect as one of these will make. Copies through SPF are fine as well EXCEPT that the last 5/8" of the copy is cut off. It's as if the scanner stops scanning before the last part of the original passes over it. When you lay the two copies side by side or on top of each other they line up with no more than 1mm variance in where the image is on the paper. Mag ratio is 100% with original test chart scale.
I've tried every TC that has to do with lead edge, and void area that I can find and while minimizing trail edge void does help a little it is nowhere near what is needed.
Any thoughts are appreciated.
