mx2600n fuser
  • cfleming91
    mx2600n fuser
    i am working on a sharp mx2600n and whenever i am copying the copies a coming out like th fuser pressure is off but the pressure is on i have changed the fuser, pressure motor at the front and fixed the fuser temp can anyone give any suggestions
  • rgcs1
    Systems Intergrator
    • 69
    Re: mx2600n fuser
    Although the attached document is for the MX2300 & MX2700 range it might be worth trying some of the things in it. hope it helps you..
    MX2300N-2700N796.pdf
    • Silvertoast
      • Feb 2010
      • 270
      Re: mx2600n fuser
      go into system settings thengo to device control then fuser control settings. change to the 28# range. the factory default is set to a very light paper weight
      • Herm
        • Sep 2011
        • 4
        Re: mx2600n fuser
        There is a bulletin for a variety of Sharp MX color MFPs with symptoms of incomplete fusing, toner flaking off, or overtoned. It says machine has never been calibrated. 22-06 report will show last time machine has been calibrated as well as custom settings print out. Solution: Calibrate machine using serve manual.
        Good luck
        TT-20367.pdf
