MX-M310 can't get maintenance message to clear
  • Jaws
    • Oct 2007
    • 236
    I have zeroed the count on just about every item, except Scan (count 12053) and tray 2 (count 32904). I have also set it to run free and the maintenance message won't go away. Anybody run across this before?
    • 23009
    Re: MX-M310 can't get maintenance message to clear
    Which maintenance message?: TA, FK, VK, ... there are lots of choices.
    • Jaws
      • Oct 2007
      • 236
      On this machine it just reads ( maintenance required ) no letters
        • 23009
        According to your report drum life: 100%
        • Jaws
          • Oct 2007
          • 236
          I reset the drum count, but there is no option to reset life.
          • oldrn
            • 166
            Check out this post:
            http://www.copytechnet.com/forums/sh...oing-away.html
            • Akitu
              Legendary Frost Spec Tech
              • Oct 2010
              • 2595
              Originally posted by oldrn
              Thanks for saving me the effort of linking my own post Oldrn! This was the exact reason I put it up here... Unfortunately CTN's search engine is a bit... Lacking?
              OP should update firmware to 2.03 and flip soft switch, indicator will clear up.
              • Jaws
                • Oct 2007
                • 236
                Awesome, I failed to find that post with a google search. Thanks a million.
                • Akitu
                  • Oct 2010
                  • 2595
                  Let me know if it helped your problem, that's the whole reason I posted the fix in the first place!
