Sharp AR-C160 Random Red line
  • lilhyperbratsmom
    I'm new to my machine. I'm getting a faint random red line on all printed pieces. Help please
  • bilyahn
    • Dec 2006
    • 1470
    Is the line from top to bottom? If so then it is the cleaning blade that is causing the problem. Normally I just clean it off and the problem goes away for awhile. Also check the toner seal.
    Good luck.
    • Jaws
      • Oct 2007
      • 235
      Drum Drive Gear
      Could be a broken drum drive gear. Machine is bad about breaking all of them.
      • wtroll
        • May 2008
        • 85
        you can try to exchange Magent primary charger with Cyan one.
        Now if you have a Cyan line, clean the primary charger and grid.
        Luca
        • mtech
          • Mar 2007
          • 307
          Is the firmware updated and is the developer unit an "N" version? You may need to replace the developer unit and developer. This was a common issue with this beast.
