MX-4101N repeating image, not sure where it is coming from.
  • CES_Imaging
    • Nov 2012
    • 65
    On a customer's MX-4101N the black and magenta colors are repeating across the page. I've replaced the fuser and transfer belt, neither seemed to correct the issue. As these both appeared at the same time, I doubt it is the drum units. Any suggestions?
    Thanks.
  • Akitu
    Legendary Frost Spec Tech
    • Oct 2010
    • 2595
    Re: MX-4101N repeating image, not sure where it is coming from.
    Thanks.
    It could very well be the drum units, they do have a tendency to sometimes wear out prematurely, and in some cases will have no typical signs of wear. The question is, however, how are the colours repeating on the page? If it's lines, obviously drums/charge unit.
    What are your respective counters at? Copies, drum crtg etc.
    • onetek
      • 318
      I had this on a 4101 2 weeks ago. Cleaning the drum units (cleaning blade) solved it for me.
      • CES_Imaging
        • Nov 2012
        • 65
        I'm not sure, I'm no longer on site.
        I'll try those next but any insight on why two could start doing this at the same time?
        • spanky
          • Sep 2012
          • 468
          stop the machine during the copy cycle and check the transfer belt to see if the image is repeated on the belt.
          If it is then the culprit before transfer, which is the drum unit or the LSU.
          I agree that the problem is probably the drum unit.
          • Akitu
            • Oct 2010
            • 2595
            Customer uses colour jobs, colour jobs will use the black and colour drums all at once. It's through this that the maintenance code AA usually appears. As stated above, try your charge grid cleaning rod first and see if that takes care of it, use the grey laser slit glass brush depending on what kind of faults are showing through.
            Without more details, there's not much more anyone can give you, though I have to wonder why you replaced the fuser to fix a black and magenta line issue...
            • CES_Imaging
              • Nov 2012
              • 65
              No no, it isn't a line. I would know to clean or replace the charge in that case. The image itself is repeating or "ghosting" after it is laid out on the paper. The regular image is printed and a faded version appears a short distance after.
              We work on several large format laser printers here as well. When they start to exhibit this symptom, it is sometimes the fuser causing it. Replacing it was just a trial to see if that would work.
              • Akitu
                • Oct 2010
                • 2595
                Ah, with the details it makes sense. Does your customer use heavy paper stock by chance? Make sure if they are that the heavy paper setting is being used, improper fuser settings will definitely cause ghosting. You're correct that ghosting is usually a fuser problem, can also be a transfer belt not properly cleaning itself due to improper staging (transfer roller popped out of place) or not cleaning properly for one reason or another.
                • DAKOTADAN
                  • Jan 2011
                  • 61
                  Check the default fuser settings. Hit sys. settings, login as admin,
                  go sys. settings, def. settings, device control, fuser control settings. make sure 23-28lb. paper is selected.
                  I have seen this setting let the fuser move images down the page and onto next page, especially doing color. Hope this helps, Dan.
                  Thanks.
                  • mojorolla
                    The Wolf
                    • 2630
                    Clean the pro reg F and R sensors and do a full calibration. Sharps run heavy on magenta with the standard color target.
                    Check your drum units for flipped blades.
                      • 23010
                      What interval does it repeat at? That tells the whole story. =^..^=
