mx-2300 trouble !!!!
  • DINGO
    • 661
    Hi
    good night friends.
    i have two mx-2300 that when scan to pc, the dark green/blue color in the original, is black on the pc?
    someone already as this? i already try a lot configurations, but no sucess.
    (of corse the copiers are updated with teh last firm.)
    thanks a lot, for any help
    • 22997
    Re: mx-2300 trouble !!!!
    Is the the scanner defaulted to monochrome? Have you tried changing some of the scan settings?
    Do the color copies look similar? =^..^=
    • DINGO
      • 661
      everything ok, only hapened in scanner mode and in the gree and blue dark color.
      regards, mate
      • ZOOTECH
        Senior member of CRS
        • 3375
        regards, mate
        Have you tried a different monitor/PC? Maybe it's just a calibration of the monitor that needs to be done.
        • DINGO
          • 661
          hi mate, thank you for your reply, but is not a monitor issue, because it hapenned with anothers monitores in the network, and there are anohert mx-2700n in the same network and this one works fine.
          regards
          • ruben
            The New Guy
            • Oct 2012
            • 1203
            regards
            No two machines are ever the same. Give the scanner a good clean, including any white references, then perform the usual colour calibrations.
            • Akitu
              Legendary Frost Spec Tech
              • Oct 2010
              • 2595
              I've had faulty scans on this unit turn out to be bad memory. Have you tried replacing the RAM chips?
