All of a sudden this machine started doing this. Using the bottom cassette the feed rollers don't move and the cassette light starts flashing. The display says "Add paper to tray 2" and there is paper in it. When the cassette is pulled out, even an inch, and put back in the light stops flashing. Trying to make a copy it may give you just one and it starts again. Never saw this before.
The cassette is programmed for the right size of paper, the switch in the back knows cassette is in. Upper cassette works fine in its place but same story when I put it to the bottom. Please help. Thanks in advance.
