Re: sharp mx 453 light prints and copies
I'm beginning to suspect ATC sensors in the DV units, having this problem a lot these days.
I've checked DV ref (around 46, too low) with 25-1, then taken ATC sensor out and cleaned it, then ran sim again and got 20 points higher. Standard reading should be 84 - 108.
However, we've also been running some compatible toner (guilty) which may not be mixing well with the developer. If the DV reference fluctuates, due to sensor or other DV unit issue, you're screwed.
Pretty sure new DV unit will solve issues but looking for cheaper solution.
