Sharp MX 3501N has loud noise and dumping " Brown " waste toner.
  • CopyFreak
    • 27
    Sharp MX 3501N has loud noise and dumping " Brown " waste toner. The waste toner hopper asby has been replaced with new. Not affecting copy quality, but noise is quite LOUD.
    The "brownish colored" waste toner is getting dumped into front side of verticle transport area and down into the paper drawers. The noise almost sounds like a really loud humming / groaning, not really a grinding gear type noise. Maybe a locked up stepper motor..but I noticed the waste toner stirring motor did turn at times??? Not much exposure to this model but would like any advice before we follow up with this long-distance client.
    Thanks in advance !!!
  • ZOOTECH
    Senior member of CRS
    • 3375
    Re: Sharp MX 3501N has loud noise and dumping " Brown " waste toner.
    The "brownish colored" waste toner is getting dumped into front side of verticle transport area and down into the paper drawers. The noise almost sounds like a really loud humming / groaning, not really a grinding gear type noise. Maybe a locked up stepper motor ?? Not much exposure to this model but would like any advice before we follow up with this long-distance client.
    Check your primary transfer belt, it might be torn.
    • CopyFreak
      • 27
      Wouldn't that affect copy quality ?? CQ seems good on B/W & Color.
        • 23009
        Yes that's correct. It would at least cause terrible copy quality, and paper may not even pass if the belt is tangled. You may have fused toner rocks in the primary belt cleaning unit. For a copier, it's like passing a kidney stone. =^..^=
        • ZOOTECH
          • 3375
          Sorry, I missed that in your original post.
          • glewisme
            • Nov 2009
            • 240
            Blackcat is more than likely spot on. I've seen it many times. Waste toner coil gets bound by toner stones causing the drive gear to skip.
            • petee7364
              • Jun 2013
              • 7
              sounds like the cleaning blade on the main transfer unit has flipped over.
