ARM277 perfect parralel lines cover page 1/32 apart only glass and ADF, but not print
  • Jaws
    • Oct 2007
    • 235
    Lines about 1/32 apart cover page top to bottom (see attachment) when using the glass and adf, not when printing. Is it a memory chip problem or a CCD problem. Picture has shading issues, the original is perfect.
  • ZOOTECH
    Senior member of CRS
    • 3375
    Re: ARM277 perfect parralel lines cover page 1/32 apart only glass and ADF, but not p
    Try removing the fax option, I've some weird symptoms when that's been installed. I'm not sure how the copy process versus the print is performed on the IMC pwb, but that might be a good starting point. The firmware looks up to date, but a re-flash wouldn't hurt. Is the problem consistent with every copy, or is it random?
    • Jaws
      • Oct 2007
      • 235
      Consistent with every copy. I am going to change the CCD Monday to see if that makes a difference.
      • DavePo
        • Jul 2008
        • 303
        You may want to have a IMC pwb just in case.
          • 22999
          I would physically check to see if there are any memory upgrades. Both show as 0MB, so if there is a DIMM it is dead. =^..^=
          • lky1978
            • Mar 2009
            • 483
            replace the imc board first before you go to change ccd.
            • Jaws
              • Oct 2007
              • 235
              And the winning solution, after trying ccd and Imc turns out to be the MCU PWB
              Thanks for everyones input
              • ZOOTECH
                • 3375
                Thank you for updating the solution.
