E7-14 error
  • teklife256
    • Sep 2012
    • 164
    E7-14 error
    This error E7-14 has come up twice on a brand new mx-5141. The first time was the day of the installation at the the customer site. Clearing the code by cycling power it did not return that day. Now, about a month later the customer called in to report it occurred again. By cycling the power the code was cleared. If I recall correctly the customer stated the error occurred when they were scanning via df. The first time the error occurred I don't recall what function was being done. Any help would definitely be appreciated. Thanks
  • Akitu
    Legendary Frost Spec Tech
    • Oct 2010
    • 2595
    Re: E7-14 error
    Manual says check and/or replace SCU PWB.
    • gateway.vly@gmail.com
      • Dec 2007
      • 52
      Re: E7-14 error
      Originally posted by akitu
      manual says check and/or replace scu pwb.
      i have same problem with mx m282n . How to fix the error any solution
      • Akitu
        • Oct 2010
        • 2595
        Re: E7-14 error
          • 23010
          Re: E7-14 error
          Hellooooooooo? (hellooo, hellooo, hellooo ... ) Anyone listening? =^..^=
          • austonrush
            Sharp & HP Tech
            • 242
            Re: E7-14 error
            I'd try Replacing the CCD next and remember to change the ccd cable as well. If that doesn't work I would be calling Sharp Direct, main boards would be next...!
            • teklife256
              • Sep 2012
              • 164
              Re: E7-14 error
              In speaking with Sharp Tech Support I was advised to try the following:
              -turn off compression for Black and White
              -set compression to low for color.
              -set exposure from Auto to manual and set to 2
              -reseat ribbon cable and all connectors test
              The error code is intermittent when scanning around 40-60 sheets from the spf. Have not heard anything yet from customer and will be following up with them tomorrow. Will post my results.
              • sharptech1
                • Oct 2011
                • 163
                Re: E7-14 error
                last resort, replace scu, ccd, and cable as set.
                  • Dec 2007
                  • 52
                  Re: E7-14 error
                  please tel where i can turn off compression for black and white
                  • piculito
                    Did the code come back? I have the same problem
                    • teklife256
                      • Sep 2012
                      • 164
                      Re: E7-14 error
                      No solution yet, customer reported the error continues when they scan a stack of docs. My next move is to check the cables for ccd and scu.
                      • faxman28
                        • 435
                        Re: E7-14 error
                        has the scu pwb been replaced ? If board hasn't been replaced yet, try just flashing scu firmware in sim 49.
                        • mercer
                          • Sep 2015
                          • 7
                          Re: E7-14 error
                          did the firmware fix it??
