sharp ar337
  • Copier Systems
    sharp ar337
    have a ar287 will go into a please waite sometimes then sometimes wii go from cold start to ready
    Fuser lamps working fine
    Not a fuser prob
    Removed and cleaned flash roms and copier copies copies
    Know this is only atemp fix but has anyone experienced this before.
    AndyH.
    • 23010
    Cougar or Leopard?
    So is this a Cougar or a Leopard? There is a huge difference between the AR-337 and an AR-237.
    • Copier Systems
      That sharp is ar-287
      Copier Systems Looked at to many machines yesterday.
      AndyH. Copier systems
        • 23010
        AR-287 is a Cougar. Though it's less common on the "7's", cold solder joints on the power supply can cause some very strange effects.
        Remove the DC Power Supply and examine the solder joints for all of the larger power transistors, and the solder joints for the AC connectors. Magnification helps. Often the solder joints can be repaired. I have a 9 out of 10 success rate for repairs of these.
        Also make sure that your ground to neutral at the wall is 0.5 vac or less. This also can cause some stange occurrances.
        Good Luck. =^..^=
        • Copier Systems
          Sharp ar-287
          On the please wait that is intermitted if i remove the finisher everything works great the problem is comm between the copier an finisher in diag
          everything works good will revisit connection between finisher an copier
          any help would be helpful
          Thanks Andy H.
            • 23010
            Ooh! Good clues. This is ringing a bell.
            When you have a bad PCU PWB one of the accessories will work really unpredictably, usually the RADF (not on the display, functions not available, errors, etc.). When the accessory is removed all function is restored (except for the accessory, of course).
            I recall selling several Cougars without finishers just because that portion of the PCU was fried. Later on I was tasked with assembling two Cougars from the graveyard. The only problem was that I could not find two good PCU's of 10 corpses.
            Try the PCU. =^..^=
