od SF-2314
  • DINGO
    • 661
    od SF-2314
    Hello friends
    i have a old costumer copier model SF-2314 that the copies are all blacks almost like when the copy lamp is broken.
    so, i already chek:
    -copy lamp is work ok, good light.
    -the group of litle lamps, that are into the copier, up the drum are goods to.
    -the drum is ok to
    -developer is good to
    -the mirrors and lent are very cleaned.
    -and the sm 46-01 are adjust fine.
    -and last, the copier there are many years that are stoped, but only as about 3000k copies (realy), because
    was sold by us to.
    (there are a long time that i do not work in this model)
    any help i m glad.
    thank you so much
  • vincent64
    • 382
    Re: od SF-2314
    I recall seeing this the first time I worked in the field and it was on one of these little machines, was my first solo call, try and replacing the exposure lamp, its getting weak, that's what it was on mine, lamp still lit up, but not enough, even tried to max out exp settings in TC 46, I replaced lamp, and it went to working again.
    • harleyrider
      • Oct 2011
      • 348
      Re: od SF-2314
      Yes it maybe the exposure lamp. You have to remember that this model is aprox. 12 years old. The drum developer etc. may be that old also. You will probably spend more than it is worth to try to fix it.
      • oldrn
        • 166
        Re: od SF-2314
        You say that the drum is ok. Is it a new drum, fairly new or it just looks good?
        Is the drum being cleaned by the cleaning blade?
        Are they using Sharp toner or whatever they can find?
        • DINGO
          • 661
          Re: od SF-2314
          hello
          -the drums "looks good", not a new one, i mean, and is cleaned good by the clean blade.
          -ok, the copier only as 3000 copies, but there are the years, i do not now if the years
          are the issue.
          about the copy lamp, i will go check this, but there are a good light.
          thank you all
            • 22999
            Re: od SF-2314
            Dingo, this machine is a piece of crap, not worth an hours labor. Just dig a hole and throw it in. =^..^=
            • lky1978
              • Mar 2009
              • 483
              Dingo, how about the developer cleaning seal? if broken also can result in main corona dirty, dark out put.
              Oh, just recalled my memory, got two mirrors after the len, have you cleaned?
              • MHeon71
                • Oct 2008
                • 489
                Re: od SF-2314
                I have not worked on an analog for many years and forget what codes it would pop, but could there be something with the MC unit. If MC was no charging drum, would it give black page. I would think it pop a C1-00 code but I could be wrong.
                • Madnhain
                  • Dec 2012
                  • 148
                  Re: od SF-2314
                  This machine is before my time... so forgive my ignorance, but I've seen similar stuff when the CCD is out of alignment. Does this antique have a CCD?
                  • MHeon71
                    • Oct 2008
                    • 489
                    Re: od SF-2314
                    No, analog machines had a series of mirrors that shined directly on to drum surface to form latent images. No CCD
                    • DINGO
                      • 661
                      Re: od SF-2314
                      thank you so much all people.
                      was the copy lamp, it seems look good, but realy is not good.
                      thank you once
                      • Brian8506
                        • 1664
                        Re: od SF-2314
                        This is CTN's greatest asset. Somebody will always be here to step up and tell it like it is.
                        • DINGO
                          • 661
                          Re: od SF-2314
                          hi mate,
                          i already post the fix ago in this post.
                          the issue was the copy lamp that was bad,so i replace by a new one and the copier its good now.
