Sharp MX4501 Color Quality issues. Black ok.
  • chris_c
    • May 2012
    • 34
    [CQ] Sharp MX4501 Color Quality issues. Black ok.
    I have an MX4501N with color quality issues on both copy and print. I have replaced all color DV units (due to a separate mag roller issue), DV, drum units, primary and secondary transfer units. The main drive unit is only 6 months old. Tried to calibrate, but TC 50-22 fails. Tried adjusting black LSU skew, setting defaults with TC 50-20, but still have a density/quality issue. Called Sharp and was told LSU, but I'm open to other suggestions.
  • Akitu
    Legendary Frost Spec Tech
    • Oct 2010
    • 2595
    Re: Sharp MX4501 Color Quality issues. Black ok.
    50-22 can and will fail if the main drive gear of the transfer belt is broken. I've had belts with sub 5k copies on them break the back of the gear and it spins in place.
    If your gear is good, I'd side with sharp that it's the LSU. Make sure your alignment pin is centered as a start and continue fiddling until your 50-22 works. Those lasers are a real pain in the ass to reset if they've been horribly misaligned.
    • chris_c
      • May 2012
      • 34
      Yeah, I put a brand new primary belt unit and still got the same results. I think I adjusted that slide for an hour before I gave up and ordered a new LSU. Going to try to install it today if it comes in.
      • chris_c
        • May 2012
        • 34
        Pretty sure it was an issue with non OEM toners. The other tech here had the same issue on a different machine (same model). He replaced the dv and put in Sharp toners and that did the trick. My customer decided to get a new copier before I was able to try it on this model.
          • 23010
          Do you remember he detail code when 50-22 failed? =^..^=
          • Akitu
            • Oct 2010
            • 2595
            In my experience with 50-22 it will give (main/sub + colour + front/rear + value) as the error, none of which is terribly specific aside from what colour is having the fault.
            • chris_c
              • May 2012
              • 34
              It was a sub magenta code. Don't remember the number. All of the color images were "washed out", but the magenta was the worse.
              • Sam Tofu
                • Dec 2007
                • 130
                RE comp toners on color machines.
                From our experience. We have never seen good results on machines where customers have been using comp for Copiers ANY MANUFACTURE copiers all seem to need OEM.
                Now for some reason with smaller printers HP OKI etc. we see (when a good quality re manufacturer such as MSE etc) then they seem to be ok. Not certain why. All we know is NEVER use comp color toners on larger copiers
