Aries2 (MX3640N) just placed
Re: Aries2 (MX3640N) just placed
we had one in the office that did this as soon as it was unboxed. tried everything swapping boards with another like machine. i think my manager finally found it to be the scanner control pwb. i will have to double check tommorrow at work but im pretty confident that was the culpritComment
Best Regards;
PaulComment
looking at wiring diagrams and your info, looks to be scn pwb and or lsu mother pwb. cn 104 pin 1 activated by relay on dcps. Relay is controlled by PCU pwb. cn 106 pin 6 and 7 are control signal from lsu mother pwb(which is activated by control panel power sw) and goes to dcps to turn on and activate signals to turn on other parts of copier. as I have not seen a power up/on sequence in sharp service manuals (this is from similar issues on sharp mfp's and talking to tech support. ) I would still check all power voltages and disconnect options and connectors to narrow down the failure, As I have had suprises and a pwb that you would think is not related ends up being the problem.Comment
Re: Aries2 (MX3640N) just placed is now fixed
looking at wiring diagrams and your info, looks to be scn pwb and or lsu mother pwb. cn 104 pin 1 activated by relay on dcps. Relay is controlled by PCU pwb. cn 106 pin 6 and 7 are control signal from lsu mother pwb(which is activated by control panel power sw) and goes to dcps to turn on and activate signals to turn on other parts of copier. as I have not seen a power up/on sequence in sharp service manuals (this is from similar issues on sharp mfp's and talking to tech support. ) I would still check all power voltages and disconnect options and connectors to narrow down the failure, As I have had suprises and a pwb that you would think is not related ends up being the problem.. Pin 1 of CN104 is now at 5v, but the two signals at CN106 pins 6 and 7 read the same as before.
Thanks for your input faxman28 and others, it helped a lot."You can't trust your eyes, if your mind is out of focus" --Comment
(MX3640N) not printing
Hi folks;
I met the same model sharp MX3640N today to solve the single problem "not printing" from computer, I spent hours but unable to figure out. I feel humble to ask some advice, as I have been successful in configuring network setting hundred times for all Ricoh machines.
switching from DHCP to static, reset Nic , test page can be printed out from the machine only, but unable to print it from PC, re-installed the drriver, Win8 Pro, built in driver,still says "error" in queue , job status show nothing. computer and the machine can ping each other,
One thing made me puzzle is that "WINS" from network service is blank. but the printout test page show host IP address 255 (like 192.168.2.255) and marked * besides, obviously it is broadcasting . And further I can NOT open web monitor from URL address . Windows Network Discovery listing the machine. problem is that customer don't want to say anything if their computer or switch or router has made something. I have to check one by one.
ThanksComment
Re: (MX3640N) not printing
Hi folks;
ThanksCthulhu for president! Why settle for the lesser evil?Comment
If it is Windows 8, you most likely got a WSD printer port. Avoid that port type like an Ebola sandwich.
When you install the driver, if you choose to "discover" the device, you get a WSD port.
Instead, choose the manual install, enter the actual IP address; you will have much fewer issues.
Also, set the port settings to LPR, enable byte counting and name the queue lp. Picture below.
You can also hook a laptop direct to the machine and test the NIC card and print functions. If that works, it is the network.
Failing to plan is planning to fail!!!Comment
[ATTACH=CONFIG]26812[/ATTACH]
blackcat: Master Of The Obvious =^..^=Comment
I had to replace a touch sensitive Home button once. Due to getting shocked. MFP located on carpet.
To get around it I used the F11 key as the home key.
Which for some reason no one seems to know.
F11 = HomeComment
