Touchpanels for Sharp.
  • Hansoon
    • Sep 2007
    • 3388
    Would like to know which Sharp models are suffering from the dreaded touch panel disease of unresponsive touch panels.
    Lots of thanks in advance.
    Hans
    • 23009
    Re: Touchpanels for Sharp.
    I haven't seen any on Sharp. They must have better technology for the panels. =^..^=
    • Hansoon
      • Sep 2007
      • 3388
      *cough* *mumble* *cough*
      Hans
      • RascalMJ
        • Mar 2009
        • 174
        Hans
        I had a customer recently call on for a scanning issue, and while on the phone she mentioned her touchpanel was "slow", she would count a 10 second delay from the time she hit one of the buttons to the time the machine would complete the activity.
        This was a brand new instal of about 2 weeks prior. They are on scan to e-mail so I figured it was a network problem on their end. I was kind of at a loss on the touch panel scenario, so I recommended the 'ol power cycle. She called back about 10 minutes later and said that seemed to fix BOTH issues.
        • DavePo
          • Jul 2008
          • 305
          There is a setting in system settings for touch length that can be set up to about two seconds. Have seen this messed with.
          • CorbinDallas
            • Mar 2012
            • 56
            Touch Panels
            The first generation of the new style display had a slight response delay. Models such as the MX-3610N. Updating the firmware to version 7 or higher will improve the response.
            • Hansoon
              • Sep 2007
              • 3388
              Nice input guys but that doesn't help me.
              Sharp's are not suffering from UNresponsive touch panels??
              Hans
              • ZOOTECH
                Senior member of CRS
                • 3375
                Hans
                Not from what I've seen.
                • harleyrider
                  • Oct 2011
                  • 348
                  Haven't run into any yet. Knock on wood.
                  • RascalMJ
                    • Mar 2009
                    • 174
                    Yeah, I told her that it was likely something someone messed with, without knowing. However, according to her a reboot fixed the issue... so not sure about that.
                    Hans
                    Nope. ZERO that I have seen
                    • mojorolla
                      The Wolf
                      • 2627
                      Coming from a Panasonic background, I have to say Sharps touch pads are pretty well made.
                      The Panasonic part number DZTE000044R is burnt into my brain!!!
                      • CorbinDallas
                        • Mar 2012
                        • 56
                        If it doesn't work at all and has not been previously disassembled, there may be debris in the edges of the touch panel locking it out.
                        • igi
                          • 1507
                          Hans
                          bless-you
                          • bilyahn
                            • Dec 2006
                            • 1470
                            Haven't had any unresponsive touch panels but the new ones seem to "drift" and have to be recalibrated every so often. Maybe this is what you mean by unresponsive? Also had 1 touch screen with a small dent in the surface and that area of the screen was screwed up in a 1" X 1" area, rest of the screen worked just fine.
                            Have a great day.
                            Bil
                            • Hansoon
                              • Sep 2007
                              • 3388
                              Yes, that's the problem. It starts with "Drifting" as you call it and than after some time the touch panel is not any longer reacting to the inputs and cannot be recalibrated but has to be replaced.
                              What are those newer models? I'm not a Sharp guy, that's why I'm asking.
                              Hans
