ar m237 f6-10, f6-88 codes
  • walterman
    • 196
    I am getting F6-10, F6-88 codes from the fax portion of the mfp. I have tested the incoming fax line,I have reseated tel/liu pwb, the fax pwb as well as clean and reseat the rom. I have preformed a sim 66-10 as well,and the fax is still not working. My question is do I replace the entire ar fx7 or is there another solution? Correction on the box it is an AR M257.
  • ZOOTECH
    Senior member of CRS
    • 3375
    Re: ar m237 f6-10, f6-88 codes
    Try setting soft switches to default with TC 66-2.
      • 23008
      The Leopard takes an AR-FX4 not an AR-FX7. I have no reason to believe that the AR-FX7 is compatible. Did it ever worK? I wouldn't think so. =^..^=
      • Akitu
        Legendary Frost Spec Tech
        • Oct 2010
        • 2595
        These codes were a known issue on this series, the battery on the fax board died prematurely and it would code out as a result. Workaround was to disable the sleep/shut off timers. I've had it be a single speck of dust on the fax ROM chip as well as an issue with the ground from the outlet.
        My manual for both 237/257 both show the ARFX7 as the required fax kit...
          • 23008
          Thanks Akitu. My manual is clearly 8 or more years older than yours.
          • walterman
            • 196
            Thank you for the responses, I will check the ground on the outlet and see if that is grounded properly. As far as the shutoff times go, the mfp acts like it has a telephone hooked up to it and I can't hear a dial tone when in speaker mode, I even checked the speaker connection, before it even goes in to powersave. I will follow up after I check the ground.
            • Akitu
              • Oct 2010
              • 2595
              When you say it acts like it has a telephone hooked up to it but there's no dial tone - are you saying the line light is active but there's no dial tone?
                • 23008
                I think I would dig out the analog tel line tester, to see if you even have a functional phone line. =^..^=
                • Akitu
                  • Oct 2010
                  • 2595
                  You took the words straight from my brain, I would think these older babies might not play too well with a digital phone line.
                  • poekeypop
                    • Feb 2014
                    • 16
                    replace liu pwb, had that a few times, make sure machine hooked to surge box.
                    • walterman
                      • 196
                      Yes, when I connect the fax to the mfp, the lcd display shows telephone mode and acts like it is a telephone off the hook but no sound. I know what you mean about the old stuff not liking the new digital lines, however, I have never had this problem with this particular fax kit with digital fax lines. I am waiting on the customer to approve the quote. I will let you know if the liu board resolves the issue, thank you all, for the knowledge shared on this issue.
                        • 23008
                        How much does it cost to connect an analog phone set? Maybe 10 minutes labor? How about an additional $10 if you have to buy a handset? =^..^=
                        • walterman
                          • 196
                          I appreciate the response black cat, however I tested the line with my anolog phone from Wal -World and I hear the dial tone, the customer also had the phone line tested by the provider prior to me going there.
                          • Akitu
                            • Oct 2010
                            • 2595
                            Make sure your firmware is up to date. Bring a laptop capable of a serial connection with you on site and make sure you have the required software and firmware files on hand. That would be about the best thing that could be suggested regarding hooking up an ARM237 to a digital phone line... You may want to try replacing the fax board battery as well.
                            • faxman28
                              • 435
                              I have seen this happen when a 4 wire phone cord is used instead of the 2 wire cord that comes with the fax.
