Sharp AR257
  • Tech2002
    • Aug 2008
    • 334
    Sharp AR257
    Have a clicking noise that I am familiar with. The normal fix is either changing out the Drum and if this hasn't work I have changed out the Drum Unit itself. Usually this does the trick, but today it continued. Question is has anyone had similar experience, and if so, what was your Fix? Appreciate any input -
  • rocky_biskit
    • Jun 2009
    • 76
    Re: Sharp AR257
    Did you check the toner? Sharps are very famous for "clicking" noises when the toner gets low. I am sorry if my response seems condescending, but sometimes we techs will miss the most obvious.
    • Tech2002
      • Aug 2008
      • 334
      Re: Sharp AR257
      Nothing condescending about your response - Toner is almost full and the client changed it out because she thought this would make her copies darker.
        • 23008
        Re: Sharp AR257
        Have you looked at the gear on the rear frame that drives the fuser? Fuser Gear 19T: NGERH0090QSZ1
        It will last 2 PM cycles. =^..^=
        • Tech2002
          • Aug 2008
          • 334
          Re: Sharp AR257
          Good point - how is that gotten to? Taking out the Drive Unit or from the Drum - DV Unit cavity?
          • MHeon71
            • Oct 2008
            • 489
            Re: Sharp AR257
            Take out the fuser and you will see it on the rear frame side. Once you see the drive gear, you'll see how to remove it.
            • Tech2002
              • Aug 2008
              • 334
              Re: Sharp AR257
              Thank you - appreciate the tip!
                • 23008
                Re: Sharp AR257
                It's wonderfully easy to get to. Any of the other gears ... well that's another thing. Main drive disassembly.
                If your gear is dark brown like dark chocolate, you might as well change it anyway, as the gear teeth will start breaking off any second. They start out as white Delrin. =^..^=
                • Akitu
                  Legendary Frost Spec Tech
                  • Oct 2010
                  • 2595
                  Re: Sharp AR257
                  I've had the gears that lift the paper trays shatter in half somehow, that causes some loud clicks
