sHARP mx 3640
  • mabro1974
    • Feb 2013
    • 39
    sHARP mx 3640
    I have a MX3640 which has a squeaking noise which i am unable to find,just wondered if anyone had had any similar issues with this model. I have gone through the usual checks.
    Thanks in advance
  • ZOOTECH
    Senior member of CRS
    • 3375
    Re: sHARP mx 3640
    Thanks in advance
    By the 'usual checks', do you mean the load test to isolate where the squeak is generated?
      • 23008
      Re: sHARP mx 3640
      What are the usual checks? Specify please.
      For me, the usual checks are to run the motors individually for in service mode, until I find the one that's chirping or squealing, or whatever sound you're seeking. Sharp doesn't make this particularly easy, like putting all the motor simulations together in one group, but they do use a convention. Look for the x-1 or x-3 (sub one or sub three) simulation under each of the major groups. If I were you, I'd print off this list that I've looked up for you, and individually run the motors:
      Scanner 1-1, 1-5
      ADF/RADF: 2-3
      Finisher Motors: 3-3
      Desk Motors: 4-3
      Engine Motors:6-1
      Duplex (ADUM): 9-3
      Toner Supply (remove toner cartridges before running): 10-1
      Developing (remove toner cartridges before running): 25-1
      Actually I would have skipped right to looking them up for myself, then ran the motors.
      • faxman28
        • 435
        Re: sHARP mx 3640
        check idnc for 3640 bulletin, there was an update due to excessive toner build up on the web causing a noise. Also check paper feed drive unit, they have been squeakers on a few machine series.
        • bilyahn
          • Dec 2006
          • 1470
          Re: sHARP mx 3640
          I'm with faxman on this. Check the fuser web sticking to the belt causing it to squeak. Have had this happen on both of our 3140's and I believe the fuser is the same.
          Good luck.
          Bil
          • mojorolla
            The Wolf
            • 2626
            Re: sHARP mx 3640
            There is a known issue with the fuser web. The fix is to route the web over the silver rod instead of under it to keep the web from stalling.
            • Daveyboy
              • Feb 2011
              • 18
              Re: sHARP mx 3640
              Hi there,
              does it have an internal finisher? If so the rear bearing sweek.
              ive also had the bearing at the bottom rear of right door doing it when feeding.
              bit of oil a spot on.
              good luck
