Simulation to run specific parts of the copier individually?
  • CES_Imaging
    • Nov 2012
    • 65
    One of the techs here is looking for a simulation or some method to run individual parts of the machine. (MX-4101N) I believe it is to locate a squeek in a customers machine. The areas of interest are the Fuser and Document Handler. Is there some way to do this?
  • ZOOTECH
    Senior member of CRS
    • 3375
    Re: Simulation to run specific parts of the copier individually?
    The service manual explains several test commands that can be used. (You better hurry though, Paul <JustManuals.com> is thinking of raising the price for manuals.)
      • 23008
      Scanner 1-1, 1-5
      ADF/RADF: 2-3
      Finisher Motors: 3-3
      Desk Motors: 4-3
      Engine Motors:6-1
      Duplex (ADUM): 9-3
      Toner Supply (remove toner cartridges before running): 10-1
      Developing (remove toner cartridges before running): 25-1
      These are the appropriate sims, but ...
      I strongly recommend that you have the manual open in front of you, so that you know what to expect when you run these motors.
