AR-M237 2" black across page using doc feeder
  • axyun
    • Aug 2007
    • 1323
    When using glass copies are fine. When document feeder is used there is black are 2" thick across page. Is this some kind of white balance adjustment or width detection problem using adf? Your help is appreciated. Frank/ActionPhotocopy
    • 23010
    Re: AR-M237 2" black across page using doc feeder
    Does this band run in the feed direction, or crossfeed? Does it have sharp, crisp edges, or fuzzy, fading, or uneven edges? Solid black (K=100) or something less than 100% fill? How about uploading a scan? =^..^=
    • axyun
      • Aug 2007
      • 1323
      It was explained to me by a friend in the business. He borrowed an rp3 radf from me but I have not seen the machine myself yet. I will take a look myself on tuesday as he is closing shop monday. I have 2 sheets he gave me but don't know whether the black border is in paper feed direction or front to back of machine. It goes from black to gray and then white. Frank
      • ZOOTECH
        Senior member of CRS
        • 3378
        If optics are not absolutely square, you could get a good copy off glass, but not through doc feeder.
        • axyun
          • Aug 2007
          • 1323
          Thanks Paul. My friend said he check the optical unit carefully but he may have missed something.
          • axyun
            • Aug 2007
            • 1323
            The black area running in direction of paper was due to damaged right side hinge which I ordered this afternoon. Doc feeder being forced slightly out of position Thanks again to all for your input. Frank
