Scan to Email
  • teklife256
    • Sep 2012
    • 164
    Scan to Email
    There was an odd problem I had this week in working on an Inbound Routing call. The customer wanted to add a few email addresses to their Inbound Routing program. The current program was setup to forward faxes to a network folder. The mfp is a B402SC. Rumor had it that the faxes could not be forwarded to a network folder AND an email address at the same time. IDNC did not have a bulletin nor did I see another post regarding this. (Not sure if this is true) To be safe I decided to remove the network folder as a destination for forwarding and entered only the email as a forwarding destination. However, the selected internal email addresses would not receive the faces. The forwarded faxes would successfully be received at Hotmail, gmail and msn email addresses. For some reason the forwarded fax would not land in the internal email addresses. One particular idea was that their email provider could be employing a firewall/security solution. Realizing that that email provider was unreachable at the moment I decided to have a second look at the network settings. Everything looked good and combined with the fact that the faxes were being forwarded successfully to multiple email addresses I did not expect to find the answer within the mfp's settings. The "Reply To Address" within the smtp settings seemed odd. copier_upstairs@domain.com. The underscore in the address looked wrong. After removing the _ from the address the faxes began to forward to the internal email addresses.
    Thoughts??
    • 23008
    Re: Scan to Email
    Yes it's one or the other, not both simultaneously. And yes you'll find that Sharp and Samsung products do not deal well with special characters in the addressbook entries, that includes underscores. =^..^=
    • teklife256
      • Sep 2012
      • 164
      Re: Scan to Email
      What seems particularly strange to me is that the underscore in the "Reply To Address" (copier_upstairs@domain.com) was allowing the forwarding to hotmail, msn email accounts and others while preventing internal local domain email accounts from receiving the forwarded faxes. My personal hotmail has an underscore and don't recall any issues thus far.
      Could it be possible that their email provider has security set up that would explain this?
        • 23008
        Re: Scan to Email
        Sorry, I don't know about that. Anyone?
        • austonrush
          Sharp & HP Tech
          • 234
          Re: Scan to Email
          I can confirm you can only forward faxes to one of either an email address or a network folder, not both simultaneously.
          I've never had many major issues of getting scan to email running on a Sharp copier, I've seen some weird port issues with certain providers ie google and rogers. I cannot recall ever having an issue with a special character in an email address.
          sorry this post is not overly helpful... lol.
