MX-M950 doesnt boot up
  • Rolandito
    • Aug 2007
    • 90
    Hi Everyone
    The problem is when I turn on machine, the screen is blank...power light is on,,,but it doesnt appear sharp logo..
    I need your suggestions.
    • 23008
    Re: MX-M950 doesnt boot up
    What have you done so far Rolandito? =^..^=
    • ZOOTECH
      Senior member of CRS
      • 3375
      Ask for help.
        • 23008
        I was looking for something like: 1) opened my manual, 2) metered dc voltages on the power supply, 3) etc...
        ... but you're probably right. =^..^=
        • Rolandito
          • Aug 2007
          • 90
          Thanks black cat..
          Yesterday the machine was fine.....with jamming problems...
          When I opened front door the machine turned off..I opened rear of machine the printer control board is working
          I will check dc power suplpy....
            • 23008
            Don't forget the part about reading the manual (before asking for help). =^..^=
            • mojorolla
              The Wolf
              • 2609
              This machine has more fuses than a fireworks factory!
              They are conveniently listed in the service manual.
              • Bani
                • 34
                Had the same problem,
                check the RAM, in my case it was a 256MB RAM left upper side of MFP Board.
                • austonrush
                  Sharp & HP Tech
                  • 234
                  This is almost always a ram issue. When the power light is on but you have no screen 9 out of 10 times the ram is dead.
                  good luck.
